Jeep Rims
Dan9
Hey everyone. I am trying to decide what rims to get for my 03 tj. i think i like the american racing baja wheels but dont really know of any other ones to think about. Also i am trying to decide to between chrome and black. just curious what everyone else is using. some pics of your guys' wheels would be awesome as well. thanks guys.
It would be hard for anyone to help you decide what wheels to get. As everyones choices and likes/dislikes are endless. What color is your Jeep? I personally love the black wheels. A yellow wrangler, black wheels and accents is a sweet color!!! My TJ is black and I'm planning on getting the Rock Crawler Series 97 (Soft 8 ) or Series 51's. Pro Comp Rock Crawler Steel Wheels
I just really like the Black wheels, but others may not. Hope you find what your looking for.
thanks, yea i know it is just a matter of opinion but i'm just looking to see what other people like to see if i hear or see anything i haven't thought of already. my jeep is maroon by the way if that helps anyone make suggestions. thanks guys.
I've long been a disliker of chrome. Every car I've had I've blacked out the chrome or replaced it with black trim. The only chrome on my Jeep when I got it was around the headlights and I changed that to the black bezels the first year I had it. With that said, I'd go with black wheels if it was me.
What about the Moab wheels on the Rubi's? I ve seen a few people around NC with theirs painted black, and it looks awesome.
thanks for the suggestions guys. ive been looking online and stuff and i keep seeing something called backspacing, i saw that term on many different occasions and am confused as to what it means. thanks guys
The backspacing is the distance from the wheel mounting flange to the inside edge of the wheel.
I got a set of black with chrome outline 17" AR ATX, with Pirelli Scorpions 255X17X75R. I think it looks decent.
My TJ had chrome rims on when I bought it, and they've really grown on me.
I'd stay with an aluminum wheel that has a simple, polished outer edge.
The inside can be black, but if the outside edge is black, they are gonna look raggedy after a few trail rides in rough terrain, since a jeep wheel will get scratched/gouged on the outside edge.
Paint, chrome, powdercoat or any coating will get scratched off that outside edge. A straight aluminum outer edge will get scratched up too, but when you step back from it, it's still the same color, so it looks good.
We've recently picked up the Ion Alloy wheels and I like those a lot. Cool new wheel styles and they are very reasonably priced...
The steel wheels are cheaper, but we won't ever run them again because a fairly high percentage of them are out of round- right out of the box!
A wheel like that won't balance properly, and bigger, MT tires are hard enough to balance as is.
The steelies just have a "cheap" look to them too- JMO.
Backspacing is correctly described in jeeper99's post.
It is very important to make sure the backspacing of your particular wheel is appropriate for your tire size and lift. The smaller the number, the wider your stance will be.
The taller your lift and or tire combo, the less backspacing (wider stance) you should have to maintain room for the tires to steer and to keep the jeep stable with it's higher COG.
A word on the 16" Moab wheels. They look nice, but I wouldn't recommend them very often. If you wanna run the stock 245-16's that came on a rubi, and don't mind the harder ride of a load range "E" tire, go for it.
If you wanna run 33's, the backspacing isn't optimum at all.
16" tires are more expensive than 15's & you'll only find load range "D" or "E" tires in the larger sizes, instead of the load range "C" tires that a jeep should have.
(My 1ton dodge dually diesel truck *7,000lbs* has load range E tires on it.)
Heavier tires don't give the good ride quality or the aired down traction that a load range C tire will.
These reasons are why there are so many Moab rims on other non-rubicons out there. Most of those guys are going to a good 15" rim.
Wheels & tires are cheaper than 16's, you can find the correct backspacing you need for your rig and the tire choices in the proper load range are vast.:D
hey thanks man, appreciate it. i do want 15" rims, probably 31 or 32" tires by the way. thanks for suggesting those ion alloy wheels, the look great, decent prices too. any pics of jeeps with them? specifically some of the black ones with the silver on the outside would be cool. baja maybe? thanks
None yet.
Most of those wheels are brand new, like the 133's and the new 171's & 174's in black.
We've sold some of them, but no pics as of yet.
They are great looking wheels and you can run anything from 31's to 33's easily on a TJ. Some of them will run 35's.
