islandguy89
ok here is what happened i went out to start the jeep a week ago and it was dead i figured it was from sitting for a month so i jumped the battery and it fired right up came back out the next day and it was dead again.Here is what i have tried so far i have charged the battery and i unpluged the alternator and the starter came back out the next day hooked them back up and it was dead again so i charged the battery again and i unhooked my Aux lights and my stereo system came back out the next day i did not hook them back up and it was dead again.Today i checked the relay and everything is hooked up properly I just replaced the relay 2 years ago and the same with the battery.The only thing that i found weird was that if i charged the battery and left the cables off the battery till the next day when i went out and started it it did not start up right away there was a bit if hesitating and then it started but it was dead the next day i had the battery tested by autozone and there print out said charge and retest and that is after it was jump started and sat and ran for 10mins and put on a charger for a couple of hours and advanced autos print out says voltage 11.80v measured 388 cca Rated 770cca temperature 80'f and battery is good but low on charge.If anyone can help me figure out what is going on or what else to check or Do that would be great thanx
