Jeepz.com, freezing up?
jeepin916
Active member
Something is popping
does anyone have a problem when they use the site map tab under the Jeepz.com logo?
everytime i use it, it frezes up on me and i can tdo anything unless i press ALT, CTRL & DELete to force the program to shut down.... i dont know if its juss my computer thats doing it or if others are having problems too.
Every once and a while the page doesnt fully load,so I just re-ajust the size of the window and it loads it.
jeepin916 is right. There is something wrong that causes IE to lock up while navigating through Jeepz.com menu. -al
1999 Wrangler For Sale-$7900.00
It must be something else, I use IE and it's fine. Maybe network issues, or ISP specific. Dial up? Who knows. :?
Are you on dial up ?
I am using I.E. on a DSL connection and I have never had a problem....yet ?
Is it just this site? or are you having this net wide?
Thats why I requested that it not be reinstalled after Halloween, but NO, wouldn't listen to me, and now everyone else is starting to have the same problem I did, and still have.
My suggestion would be to move it somewhere out of the mouse pathway between the center of the page and the browser back button, or get rid of it all together.
Having a pull down site map is kinda redundant since it has everything that the menu has on the left of the page anyway.
Please remove the site map.
I've never used it, there's a link to everything so I never bothered. I did just try it with no problems with internet explorer.
i've never used it either, i use the chatroom and that is about it
Although I've rarly ever used the site map button, the times that I've used it it has worked okay.
That site menu uses the Java plug-in so certain browser versions could notice problems depending on what version of Java you have.
My suggestion is this: Forget about Internet Exploder and try the open source Mozilla Firebird browser :P :P :P .
Since switching to Firebird, I've noticed a lot less problems while using the Internet. Turns out they were all problems relating to Internet Explorer :roll:
-Nick :!:
