K.13
Just got my '95, with the 2.5, on the road the other day and yesterday decided to take it in some pretty mild trails. Just to make sur it was worth buying. So far it doesn't hold up to my old XJ.
Went through some decently deep water holes and everything was fine... up till about 30 feet from the end of the trail. Some of the points got wet, no big deal, dried them off. I did realize the coil is in kind of a bad spot. Is there a good way/space to relocate that too?
Also, seem to be having a bit of a fuel delivery problem now. Once I got it running again, a few times it just lost all power then died, and once on the road it completely stalled. After bleeding the fuel out of the valve on the fuel rails, it ran fine again. After a few problems, it seems to be ok now.
But still want to make sure.
I don't think it's a fuel pump problem. Although I should check to see how much pressure its sending. What should it be pumped at?
Any one have and idea whats going or and any suggestions?
Thanks.
Thanks.
