C Cheif Oceola New member Jun 16, 2011 #1 Fluid leaking onto my floor board from the clutch pedal. Fluid in master cylinder decreases slowly. What should I check?
larrymo49 New member Jun 17, 2011 #2 The clutch master cylinder is probably leaking from the piston into the cab. Replacing the clutch master cylinder should do the trick. Make sure you bleed the system well after replacement.
C Cheif Oceola New member Jun 19, 2011 #3 Had master and slave replaced already. Do I need to replace the line or some connection valve?
TerryMason Administrator Staff member Jun 29, 2011 #4 I'm not sure what type of Jeep you have, but I've moved your thread to the Wrangler section
