87yj350
So I started my project. An 87 yj I have had for some time that has been sitting outside for over 4 years. I started with some fluid changes. The front diff went great. Replaced the gasket with a lube locker. The rear, not so much. The last time it was changed someone must have used RTV vs. a gasket. Thought I got it all off. Put the lube locker on and tightened down the cover. Once I put the fluid in it immediately started leaking from the bolts at 7 and 9 o'clock. I pulled off the cover and figured I would clean it up really good and try again. The lube locker gasket claims to be reusable and looked in good shape when I pulled it off so I'll give it another shot. Any thoughts? Think I should place some RTV on the gasket or maybe just skip the lube locker and go with RTV alone as it seemed to not be leaking before.
