lift kit
trebyelrae
i have currently purchased a used jeep it is a 2004 wrangler and it has 31x10.50 tires on it does this mean it already has a small lift on it??
thanks for any help
maybe look on the top of the springs if there is a thick bushing probably 2"thick then yuo have a small lift
I run 31s on a stock suspension that has a little over 100k on it.05 tj.
trebyelrae said:
thanks my next question is how much of a lift would i need to run 33's would a 2 inch lift work
I would look at old man emu and there 2" lift. Or rock road puck lift. Don't know much about the puck. It goes under the spring like a seat.
Humph. Why didn't my post save??
What are your plans for the jeep? I mean what type of offroading you doing, Heavy, Moderate light or none?
This is a common question. Do some searching I say this not to avoid answering but to give you a chance to read and see what others did and issues you may encounter.
Here is a few found in a 2 min search.
http://www.jeepz.com/forum/cj-yj-tj-jk/32492-how-much-lift.html
http://www.jeepz.com/forum/cj-yj-tj-jk/32527-3-4-inch-lift.html
http://www.jeepz.com/forum/cj-yj-tj-jk/32457-4-lift-no-enough.html
http://www.jeepz.com/forum/suspension/29510-wrangler-death-wobble-what-causes-how-fix.html
