Long arm components on stock springs?
JeepNaked
Can i install the skid, arms and tri link without swapping springs yet? i dont have the SYE short shaft kit just yet, but wanted to get the ball rolling so everything doesnt have to happen all at once. my plan was to put on the belly pan with the arm mounts, and just put the lower control arms on for the rear, and the top and bottom CA's in the front. if it helps its a full traction 6in lift
yes, but once you put the new springs in, you'll have to probably re-adjust all your links.
I'd be concerned that you couldn't adjust the control arms short enough for use with stock springs. I would ask the manufacturer.
I had considered both possabilities. Asking the manufacturer is a good idea. Never thought about that. I will send em an email.
Just spoke with a gentleman at full traction and he was extrememly helpful. But he said that it wouldnt work with the kit i have. bummin, but oh well. I wanted to start putting this shiz together!
