Anyone know where i can get a long shaft speedo gear 22 teeth for my Dana 300?
I have a cj7 with axel rate 2.72 on the axels and need to correct my speedomether after putting 33 inch tires on it. My original speedo gear count 24 teeth.
Kerry at transmissioncenter.net says that a long shaft 22 teeth isent available. The 24 tooth is the smallest ever made with long shaft.
I have bought a ratio adapterto connect between the transfer and the speedometer cable. I ordered the 11% speed up rate (#54RA2).
