ronpapworth
Hi all, Great board you have here!
Looking at a 94 Cherokee Sport and wanted some input. I am buying it from a private party and they are the original owner. The dash light is out of it and it just started leaking oil(they say). I am sure I can find the oil leak,but how hard is the dash light repair? I can get into dashes pretty easy(on other cars anyway) as well as long as I don't have to remove the whole darn thing.
Any other things I should look for in this model? (meaning could that dash light be an electrical problem)
UPDATE: Just back from looking at it. The oil leak is real bad and appears to either be the oil pan gasket or rear main seal. It is not coming all the way down from the valve cover, and it's not the oil filter(but it is on the passenger side of the motor). Im sure the transmission has to be dropped to get to the rear main, but can the oil pan be done without lifting the engine?
Brakes are mushy, but the resevoir is full and the pads up front look good. Front and back was done a year ago,so I don't think they should be this mushy this soon.Is that a characteristic of the Jeep cherokee? All of the lorados and limiteds I have driven were not this bad.
I can see where they tried to get into the dash to do the dash light, and I got the "well it could just be a fuse" stroy from them,but I know it's not. So back to my original question,how hard is that to fix?
So there you have it. Oil leak, no dash light an mushy brakes. Sound about right for 4200.00?
Thanks in advance!
Ron[addsig]
Thanks in advance!
Ron[addsig]
