looking for Transmission and TC advice
thbugman
I'm new to the forum and new to working on Jeeps. I have a '78 CJ7 with a 400 sbc in it. Right now it has a T-10 4spd in it. I just picked up and plan on using a sm465 and a np205. But i'm hearing i'd be better off with a T-176 and a Dana 300 set up. As of now the front and rear ends are stock. Any advice?
if it were me, I'd run the 465 and 300 unless you are going make a doubler with the 205 (203/205 doubler) then I would go that route.
the t176 was a medium duty trans with first gear around 3.7:1, it was found behind V6 and very underpowered V8's
the 465 is physically about the same size, it's a HD trans with a first gear around 6.7:1 (6.67:1 to be exact I think) was found behind some v6 but also behind any v8 gm produced and diesel motors.
depending on teh t-case you run, the 465 may or may not need adapters. the t176 will need an adapter regardless just to bolt up to the 400 (since you typed sbc, I assume it is really a 396 block from a truck)
the D300 is a good T case, takes modifications well, but they are pricey. decent low gear of about 2.6:1, does not take shock load well at all, cases are known for cracking.
the 205 is a beast, big heavy, thick castings.. but low gear is miserable, I think it is 1.8:1, not very good, but you can build a doubler with a NP 203 range box, you can also do a low-max gear swap as well as plenty of shaft spline count interchangability and upgrading.
