Try using drill bits for drilling into metal. You can still use regular ones, but if your not careful they'll heat up and snap on you. Buying ones made for metal make the job a little easier. Start small, work your way up to the bolt size. Patience is key. Twice now I've had to drill the bolt out of my wheel because I stripped a lug nut. That was 3 hours per tire lol.
