clydethepirate
I'm not sure what the problem is. My girlfriend says its Me! She say's I'm to pickey and want everything perfect................
Anyway, My new lift has settled about an inch since it was installed which I guess is normal?
However one side (drivers) is 1/2" lower than the other side.
If I measure the shackle bolts they are the same from the ground up.
From the ground to the bottom of the spring is the same on both sides and front and rear.
Could it be a bad spring? or is this normal? or is April Right? (surely not)
Could it be Rough Country? I know it's the cheaper of the lifts so should I get something else?
Any help is appreciated......... as always I'm still learning.
