motobilt
Official Vendor
HATCHET JEEP JK FRONT BUMPER
Only $299!
The Motobilt "Hatchet" Jeep JK Front Bumper is an ultra-slim design for the front of your Jeep JK. The "Hatchet" is available in a few different configurations. This "Hatchet" configuration is the base model. It has holes to mount your winch but you will need to add a winch fairlead mount which is PN MB1002 by using the pull down menu. The Hatchet includes 3/4" thick steel D-Ring mounts that pass through the bumper and our welded inside and out for superior strength. The "Hatchet" is a total of 41" wide which allows for closer approach angles. Frame modification required and vacuum pump relocation is required in Jeep JK models 2012 and newer.
Only $299!
