motobilt
Official Vendor
Motobilt Jeep YJ Front Shock Towers
SKU MB1532
Only $99
The Motobilt Jeep YJ front shock towers are laser cut from 3/16" steel plate and cnc bent in house at Motobilt. These are 100% made in America. The Motobilt towers are meant to replace the stock shock buckets on your 1987 - 1995 Jeep Wrangler YJ.
The towers come as a pair. They are bare steel and will require you to weld the mounting tabs and seams together. Also your factory towers will need to be removed completely to make room for the new Motobilt towers.
The Motobilt Jeep YJ shock towers allow you to run a standard eyelet upper shock end with a 1/2" hole instead of the factory stem style. This new style is much stronger.
They measure approximately 9.5"s from the top of the frame to the center of the shock eyelet.
The Motobilt Jeep YJ front shock towers can be used with stock width axles or full width axles.
These towers are NOT meant to be used with coil overs! Again these are designed for standard style shocks and NOT coil overs.
If you need towers for coil overs then click here for part number MB1516
You will receive 2 tower assemblies and 4 shock mounting tabs. These towers do NOT come welded.
SKU MB1532
Only $99
