Micah Chambers
Ok guys I have a 97 TJ 4.0 and I need your help!
My jeep will turn over all day and not start.
What I have done/replaced;
ignition switch(it was sticking), the rotary on the other side of the switch, coil, plugs, wires, crank poss sens, distributor sensor (inside cap under rottary button), timing chain :shock:
It all started with it taking several times to turn it over to start it so I thought fuel pump or fuel pressure regulator so changed them.
Then was told to swap my ASR still nothing
But there are times I can go out turn it over and it will start :shock:
I HAVE NO CLUE PLEASE HELP!!!! :???:
