need a new rear end ASAP!!!
Quik8slvr
Looking for a used rear end, blew out my dana 35 2 days ago, limping around in 4wd ever since....i would prefer another 35 3.07 gears preferably but 4.10's would be ok also...any axle that will bolt directly into my YJ would be perfect, if anybody has something available let me know asap.... jad8580@salisbury.edu
Thanks,
Quik[addsig]
1060718
that 350 didnt have any thing to do w/ no 35 did it? [addsig]
1060804
havin the 350 is definitely the reason that the 35 blew out, but it was also my fault for having such a heavy foot, the reason i'd like another 35 is that i didnt want to spend all the money of having to set up a dana 44 or ford 8.8 or 9" because that tends to be much more expensive, but the good news is that i found a ford 8.8" already set up with perches, shock mounts, and everything needed to go into a yj, plus it had disc breaks and a limited slip, only $700 :-D
Quik[addsig]
1064128
How would you like a matched pair of DANA 44's for less than $1000.00!!
I have a pair from a 79 wagoneer that will just about bolt in. Terry Howes Tech pages have an article that says it not a tough swap. Ill give you both axles for $600. Long Island area, I am willing to travel 2 hours from home to meet.[addsig]
1064307
I've got some 3.07's taking up space in the garage out of my '94 YJ...when I changed to the 4.11's. Make an offer...let me know.[addsig]
