Knuts311
Hey guys, I need some help. I bought a new Motorcraft 2150 with electric choke from Gronk last week, and can not for the life of me get it running right. It is replacing a Carter on a 90? 258 and with the exception of a fatal deadspot half way into the throttle it was running good. I've replaced: plugs, wires, cap and button, fuel pump, oil pressure sending unit, EGR valve, PCV valve, all vac lines, fuel filter and lines, as well as dumped the old gas and replaced with non-ethanol gas. The problem I'm having is a bad miss on idle and when revving (sometimes it clears up when revving at higher rpm, but it's hit or miss), extremely rich smell in the exhaust, black smoke, and the float bowl almost immediately empties itself when shut off. I've opened the airhorn and poured gas into the float bowl and it all drains out in about 15-20 seconds. I have also spayed the entire area with both carb cleaner and ether with no change so I don't "think" it's a vacuum issue. I dont even know where else to start looking to get these issues resolved...
