need help jeep cj7 not firing.
coachwelborn
can any one help.i have put a new ignition modgle. new coil, new distrbuter new wires new plugs .still wont firer
1042722
Did it work BEFORE you put in these new parts?[addsig]
1042747
New distributer or distributer cap?
if the distributer only,perhaps it was not put in the correct firing order?
but also make sure the module has proper ground
1042756
GOT IT ON THURS .WIFE DROVE IT FRIDAY .IWENT TO CRANK IT UP ON SAT WOULD NOT CRANK.SO THAT IS WHEN I STARTED REPLACING ITEMS MENTION IN THE ABOVE POST. IS THERE ANY KIND OF RELAY THAT I DONT KNOW ABOUT.I DO HAVE MY PLUG WIRES LINE UP CORRECTLY.I NOT GETING A STEADY SPARK FROM MY COIL[addsig]
1042760
Also, try taking off dist. cap. KEEP IT Out of the way, and turn eng. over. Is rotor turning? If it is, You can also pull off one plug wire stick an extra plug in it let tip of plug touch the engine, then turn key, does it have spark?[addsig]
1042765
i have the 84 cj7 with 4 cylinder.it shows i have power on the + side of coil but we put a omh meter on it and it was only 6 volts.[addsig]
1042810
NO NOT YET I SENT IT TO THE SHOP AND LET THEM FIGURE THIS ONE OUT.THANKS FOR ALL THE HELP IT MIGHT JUST NEED TO BE RE WIRED.[addsig]
