Re: Transmission problem.....Help Help!
First, if you haven't done so get under the jeep and see if your shift linkage is bound up, sloppy connection points. If that checks out ok, I would take the front carpet out if you have any and unbolt the transmission tunnel, unbolt the top of the transmission and lift the top cover off and look inside. As you pull the top cover off of the trans, there will be two forks that will come with it, as you lift look at where those forks are coming from (shifter hubs) and see if you can slide those forward or backward using two fingers on each side of the shifters. When you shift gears while driving, the forks that came off with the top cover of the trans move those shifter hubs (I hope that's the correct name) forward or back into each gear. If you can move them, the problem is probably not internal and would look at linkage or clutch adjustment. Assuming your clutch disk is fine. When you put the trans cover back on, the forks just slide back into the slots of the shift hubs.
