You could put a small body lift on it, like a 1" and you could put a bit longer shackles on it as well. Both should be under a hundred dollars each. If you put longer shackles on, "DO NOT" go over 2" longer than stock or you will have steering issues. You will gain half of the over stock length of the shackle for lift, say you go 1 1/2" over stock shackle length, then you will gain 3/4" of lift. Again, DO NOT GO OVER 2" longer from stock. some companies will advertise shackles as 2" lift shackles, those shackle will be like 6" longer than stock and you do not want them. so watch how they are advertised.
