I have an 83' CJ7 which I (or actually a fabrication shop) replaced the 4cyl with the 4.2 however the new alternator fused at the post making the fuseable link crispy and the battery extremely hot. After rebuilding the connections from the alternator and putting in a 30a inline fuse and replacing the alternator it does not start. Rechecked the battery and replaced it as well. Still no power to the dash, lights or other accy and still no crank not even a click. 12v is present at the HEI, to the solenoid (blue wire) and the fuse block. Replaced the ignition switch but still no change. I'm stumped and clearly missing something. Any advice greatly appreciated?
Also, I haven't tried replacing the solenoid or checking the starter as it seems I should have power to the dash lights, fan, turn sig etc.
