absolutemoon
I have a 180 degree thermostat in my 81cj7 258ci. my normal day to day operating temp is between 180-195 degrees. When I am towing approx 1200-1500 lbs the temp will increase as far as 210 deg or so. Is this normal? Would it benifit me to put in an electric fan assembly. Im not a mechanic but, I thought if you put a 180 degree therm. in the engine should run at that temp. Not 30 degrees higher. Am I doing any harm by letting it run upwards of 210 degrees? Thanks. Bryan
