T t moyer New member Aug 4, 2009 #1 oil gage problems ,new sending unit but gage reads 0 no noise from engine,oil level is full 01 grand cherokee help??????
T t moyer New member Aug 4, 2009 #3 when the sending unit was replaced it work for about an hour once in a while ill get a reading
SteelHeadz Super Moderator Aug 5, 2009 #6 Ground the oil pressure sending unit wire and see if the gauge pegs up to the max. position. If it does the problem would be on the sending unit and on. If not, it would be towards the cluster circuit.
