J-Daddy
Well it seems like my '89 XJ has turned into a giant oil slick.....I was blowing some oil into the airbox, last week I replaced all the PCV crap but it still hasnt fixed it...So there was $107 that did no good...While I had it apart I took the valve cover off, cleaned out the 5lbs of carbon build up in there and took the 2 vents apart and cleaned them, put it all back together and it's still doing it...My frame rail on the left side above the upper spring mount is covered in oil and it's running down the body onto the lower control arm mount and dripping off...Plus the bell housing is covered in oil and the crossmember so it's kinda hard to tell exactly where it's all coming from....Anyone got any ideas on this cause I'm kinda stumped.
