ok... I haven't done much looking to see what the problem is. It has been going on since mid-late august. had the oil changed in august (not sure before or after problem arose) Oil level is fine, it leaked at first but in needed a better washer so that problem was fixed. I know last late spring, when someone did an oil change they over torqued the bolt so we had to take the whole pan off and cut out the messed up thread and make a new one but it seemed to work fine then. My shop teacher thinks its the pressure switch and to test you use an oil pressure guage right? or is it worth getting a $30 replacement. andwhat is the difference between an oil pressure switch with light and with guage?
