gippersdad
It was quite a ride, but Big Red is finally back on the road!
It was, what I have now learned, is the "standard" D-35 problem. I, sometimes, pull a 16 foot trailer with this 89 YJ and the D-35...well...she didn't like that.
In any case, I looked at conversions and found that...well...nothing bolts up to a Jeep without some cutting and welding. I cannot weld. It is my limitation, so I decided to just rebuild the 35 and make it as strong as I could for pulling. Bought the master rebuild kit and gears for 4.56 gearing...front and back...because they have to be the same.
Got in there, and found out that my rear housing was warped. Now I had the gears and bearings...but needed a housing anyway. Found a guy on Craigs List who had an already built axle, with 4.56 gearing. I rebuilt the front, and just replaced the rear.
Drove that for a day...before finding out that the stock driveshaft...just won't DO that. Within an hour, I busted the driveshaft. Had to buy a heavy duty driveshaft new...but at this point...what was I gonna do?
Since I was dirty anyway, I went ahead and replaced the oil pan and valve cover gaskets...to stop those pesky oil leaks and now...finally...
I have gone two days in a row without anything else breaking.
Thanks to several of you guys on here, who helped me when I had questions!
