sirvice
FACTS: I've got an Keywest Only 2000 TJ and I want to use 5x5 wheels and 32" tires
I live in Keywest so there isn't any possibility for offroading. My friend gave me her stock 2014 JK wheels and 32" Goodyear Wrangler P255/75R17 113S tires. I want to use these on my 2000 Saharah TJ to enjoy, amoungst other things increase the value for a soon-to-be resale.
How best do I go about doing this?
From what I understand, my TJ has a LUG Pattern of 5x4.5 and the JK wheel's LUG Pattern is 5x5.
I've already purchased these:
SET GROUP Wheel Adapters 5x4.5 to 5x5 1.25"(32mm)
and hope they work. Amazon is one of the better ways to purchase & recieve goods in Keywest.
I plan to use a 2" spacer/body lift as a road only lift so that the 32" JK Tires will fit. Being in Key West, Amazon.com is the way to go for delivery of parts. I've lurked and read for a long time now and feel confident that I need a 2" body lift to allow the tires to fit without rubbing. Is this correct?
The jeep's steering damper is going to replaced as well. I wanted to make sure that the new one fits. From what I understand one of these will fit. If there is something to be desired or suggested, please don't hesitate to tell me:
Monroe SC2928 Magnum Steering Damper
or
Skyjacker 7009 HD OEM Replacement Steering Stabilizer Kit
or
Rancho RS5407 RS5000 Series Steering Stabilizer
Also do I need a a new and possibly adjustable track/sway bar?
As for the 2" lift, I understand 2" is the minimallift to allow 32" tires. I also read Rough Country is bottom tier but works well for basic driving for a year or two. Would this be ok to use for use on highway/street road?
Rough Country - 658 - 2-inch Suspension Lift Kit for Jeep: 97-06 Wrangler TJ 4WD, 04-06 Wrangler Unlimited LJ 4WD
If not, which body lift would I be better off using?
Am I on the wrong track? If sticking to body lifts, where would you go with this?
I really appriciate any energy anyone uses in replying to my query.
or
or
