Performance upgrade question
Sly8795
Score one for the Jeep dealer
I have a 90 4.0l auto and I'm always looking for performance items to put on it just for fun. They are extremely hard to find but I finally found a new throttle body that will fit this and i will be able to afford it soon. I'm wondering how this will affect my air/fuel ratio because I already have cat back exhaust and a 6x9 kandN filter on it. Ive sorta looked into it and it seems I can build a device to adjust my map sensor outputs to help with the fuel ratio. Is it a good idea to look into this because I want my engine to not only run strong but run right. Any suggestions on this would be welcome I plan on purchasing this within the next month. Has anyone built a MAP sensor adjuster? Also there was a note about changing the throttle position sensor settings? how does one go about that?
Your jeep will still run strong with that mod, an adjustible MAP may not be needed. I'm installing one (it's already built) because I've got the improved intake and exhaust + a performance camshaft.
