At first I thought a vacuum leak somewhere, but I find it weird it's doing it and you're tires lose traction. Is it when accelerating or when throttle is held at a constant? Does it do anything else abnormal? when slowing down or speeding up? In park and give it a steady higher idle? Does it start good? You ever smell fuel? Know if your getting spark? how do spark plugs look? Any trouble lights light up? These are questions that came to mind. I would start with vacuum hoses for corrosion, no seal condition and confirm spark and condition of plugs , is some things you can just eyeball
