PLEASE HELP FAST FRONT END PROBLEMS
ajfrank43
I just put on my lift kit yesterday and I'm getting some really bad shacking coming from the front end. It's so bad at times I have to stop driving. It seems to only happen at lower speeds. The lift is from TeraFlex mfg. 4in long arm kit. I also installed the front and rear adjustable track arms. I have not installed the long arms yet. I don't know what to do and it really sucks. PLEASE HELP ME. :-? :-? :-? :-? [addsig]
1063007
Did you get the front end lined up after the lift? I am not a TJ person but I can at least try to help eh? Tug[addsig]
1063225
Umm, install the long arms!!!! Your suspension geometry is way off, need longer lower arms. Have an alignment afterwards. Make sure the control arms and track bars are tight, real tight.[addsig]
1063288
oh yea , what abiut the steering damper is it old or worn out. ........replaced mine before the lift because of the same problem havent had any problems sense......... 8-) [addsig]
1063439
No man my jeep is less than a year old. I had it aligned but the funny thing is after I wrote the post I went out and checked it all out. I found out on my front adjustalbe track barone of the middle bolts that keeps it all tight was way loose :-D . Also when the driver side wheel was completely straight the passenger side was toed in way bad. So the next day it was a fixed up. Thanks guys for your interest in helping me :-D
Also Bounty Hunter, why do you say I need longer lower arms when alot of lifts don't even come with longer lower control arms?[addsig]
