poly or nylon body lift?
rtoney9
I will be lifting my 95 YJ. Which spacers are better, the poly spacers or the nylon spacers? I noticed that poly is more expensive, but are they worth paying the extra as compared to the nylon ones? Also, does putting on longer shackles (2") give you the same effect as putting on suspension lift, just cheaper. I have heard both, what do you guys know.[addsig]
1043709
I used the poly body lift. I have read in several off road magazines that the nylon, (hard), body lifts have a tendency to punch holes through the body after a while. The down side to the poly body lift is that you are limited to 1".
Stay away from the shackle lift. They will play havoc with steering and suspension geometry. They allow way too much side to side movement along with other problems. If you want to lift the jeep, pony up for a real lift kit. The manufacturers put a lot of research into their designs and wouldn't sell them if they knew people would be coming back to them with big problems.
Good luck.[addsig]
