1053677
Who has gone with the plastic instead of the steel? I have a 21 gal steel tank on my CJ now and am unhappy w/ it. It is too big and hangs down quite far, the polyethylene tank use the CJ's OEM strap system, is shorter, and the one that I'm looking at comes with a complete install kit and sending unit. My questions are do you need extended straps? Does an OEM skid plate work or is there an aftermarket plate to you used? If so, which one did you use? :-? thanks
-josh[addsig]
-josh[addsig]
