Is it throwing any codes?
To extract the diagnostic trouble codes, perform the following steps:
Without starting the engine, turn the ignition key ON, OFF, ON, OFF and ON. The CHECK ENGINE light on the dash will begin to flash.
If any trouble codes are stored in the PCM memory, the CHECK ENGINE light will flash the number of the first digit, pause and flash the number of the second digit. For example, Code 23, air temperature sensor circuit would be indicated by two flashes, pause three flashes. A long pause will appear between individual codes if more than one code is present. Carefully observe the flashes and record the exact code number(s) onto paper.
After the stored codes have been indicated (or if everything in the self diagnosis system is functioning properly), the CHECK ENGINE light will flash a Code 55.
If the ignition key is turned OFF during the code extraction process and possibly turned back ON, the self diagnostic system will automatically invalidate the procedure and must be restarted
Sent from my Nexus 5X using
Jeepz.com mobile app
