I would say to get pictures and post them but most important is to degrease the area that is covered in power steering fluid to find where the leak originates . This should determine what will need replacement. Hoping it is not the steering box and just a crimp fitting on a hose which will be ape asker and less expensive . If need be , try an old trick ; clean off the entire area ( spray degreaser and wash off ) and when dry , sprinkle baby powder . It will make it easier to see where the fluid is leaking. Degreasing should be done again before repair.
