trailjeep
2004 Jeep Grand Cherokee, V8, 4 wheel disc.
Most of the time the brakes work fine. Once in a while at random I hit the brake pedal. It feels weak and does not stop the Jeep well. The next time I touch the pedal it is fine. This only happens occasionally. I have replaced the brakes front and rear. No leaks at the brake lines or calipers. Plenty of fluid in the master cylinder. The brake problem is still there. Any ideas what I should check next??
