pulling transmission
kaw2000
I'm pulling the transmission on a 93 grand cherokee 4.0. I was thinking I could pull the transmission without removing the exhaust. Now I can't see how I can remove the dip stick bolt without getting the pipe out of there. Any advice on removing the top bell housing bolts. Thanks for any help.:cry:
After supporting the rear of the transmission with a stable floor jack, remove the transmission cross member and mount. Lower the rear of the transmission enough to get a long extension and socket to remove the bolts on the top of the bell housing. NOTE: You will have fluid coming out of the tailshaft of the transmission when it's tilted down.
Thanks again for the feed back Steel. I haven't been able to get back to it; with winter gone I guess I have no excuse not to.
