Question about rev limiter
I think it's set at 3000rpm.
Thanks I thought it was much lower than the RL setting when your in gear. On these new models if you hit it does it set a check engine light for a code? had a little issue with my wifes sandel getting stuck for moment
I haven't experienced a dtc for a momentary throttle stuck at high rpms. I do some WOT test every so often with the JK's on throttle response issues. The only thing i could think of is the pedal position sensor may have been intermittently compromised with the stuck sandal.
When it happened I was just concerned that a valve could get pinged. But it was only a couple of seconds. It sounds normal, hope it stays that way. Thanks
