Radio Infinity Gold
kwewu
I have a 94 Grand Cherokee, with a Pioneer CD that was attach to existing Infinity Gold amp. One day I went over a bump and the radio when away. I have checked and everything seems ok. I ended up jumpering the front speakers back in at the amp connection under the rear left seat, but what every connector that is messed up it will not let me jump ther rear speaker in.
Any suggestions on were the connector for this stuff is? All fuses that I could fine look ok.
Thanks,
Mike
1046067
Mike,
There is not much to the radio. I would check all connections first. If you get no sound out of any of your speakers I would assume that the connections are fine. Does sound come out when a CD is in? I has a problem with my antenna connection before it use to come out of the extension wire to the back of the deck. I would recommend checking that first. If its not power or speakers. That only leaves the attenna or the deck. I like aftermarket decks better anyways. More bang for your buck. I hope this points you in the right direction let me know if I understood the problem right...
Dave[addsig]
