Radio Problem
Matmadus
Hi, I was installing a radio today and shorted out the dome light circuit which is also the constant 12v circuit for the radio. I Replaced all the fuses, and still no luck. I purchased a Haynes manual and the wiring diagram is not the best. I was wondering if anyone has had this problem and/or knows how to fix it? [addsig]
1053891
Is nothing working or just the radio? Maybe there is a inline fuse?[addsig]
1054041
First sounds like you blew your dome light bulb and second after market stereo's have an inline fuse in it. Try swapping the fuse out and be sure you have a good ground for the radio. Also try and buying the Installation kit instead of cutting wires. Should only cost between $15 - $20 and saves alot of time. Plus bring it inside to solder up then go out plug it in and all ready to go.[addsig]
1054048
LOL....same thing happened to me...check the fuse box next to the battery. Inside you should find a bunch of big ass fuses and 2 tiny red ones. One of those is the one that you blew...I had the same problem...shorted out the hot while installing a radio and lost my dome light...ended up rewiring the radio and carried a flashlight hehe till one day I started poking around. Let me know how it goes.[addsig]
