RBP Lift Kit
JakeMisiaszek
While looking at tires and rims on the custom offsets website I noticed they sell what looks like a pretty decent 4” lift for my Jeep Wrangler it’s a Rolling Big Power (RBP) lift kit but I’ve never heard anything about them, I was wondering if anybody on here has tried one out or has one at the moment so they could let me know how it is and if I should pick one up, if it’s rough country quality I’d like to stay away lol
Thank you
Don't forget that bigger tires changes your gear ratio so unless you've got a lot of motor you'd likely want to change your gear ratio or you'll notice a big drop in acceleration.
I want to put a 4” lift on it with the biggest tires I can fit comfortably which I think would maybe be a 35 no crazy wheeling I just want a vehicle I can do what I want with and go mudding with
^^ agree^^ plus change speedo gear so odometer and speedometer is on.
4inch lift and 35s require more than most lift kits offer.
Springs
Shocks
Sway bar links longer
Longer brake lines
Adjustable track bar front and back
Bump stops
Either skid plat drop or engine mount lift or adjustable control arms.
Wheels with 3.75 back spacing.
Did I miss anything?
Regards,
JPNinPA
Sent using TapTalk
Look at Old Man Emu best springs
Currie enterprises lifts (very knowledgable)
Rubicon express
Regards,
JPNinPA
Sent using TapTalk
Springs
Shocks
Longer brake lines
Bump stops
Regards,
JPNinPA
Sent using TapTalk
If I were to buy the RBP lift kit what else would I have to buy to complete the lift that’s the part I’m having trouble figuring out and is there any lift kit to you knowledge that comes with everything I need
Not that I know of. Some have most. Minus the wheels.
Personally I'd go for quality. I did cheap already.
4 inch lift I mentioned two above. Currie and RE Express
Regards,
JPNinPA
Sent using TapTalk
