jfrabat
OK, here's the deal.  I had left the Jeep unattended for a while, and I figured it was time to do some maintenance.  After greasing, changing oils, oil filters, and the regular tune-up stuff, I rotated the tires.  But while doing so, I noticed my wheel bearings are a bit shady (I got wheel movement).  Also, the leaf spring bushings seem to be toast.  And the shocks could use a change as well (some unhappy encounters with rocks are the main culprit for the damage, especially in the rear).
So, my questions to you fellow jeepers are:
SHOCKS:
1. Are the Bilstein 5100 series worth the dough? (please tell me why; I have read that they can be a little soft...)
2. If YES, where do you recommend to get them? I understand there are some that are Jeep specific, and these are not available everywhere (mine is a YJ, by the way)
3. If NO, what brand would you recommend? It has to be comfortable enough to make 500 mile rides, but it needs to be capable of tackling offroad trails (after all, that is the reason for driving the 500 miles each way!).
BUSHINGS:
1. Poly or Rubber? Is Poly TOO hard? Will rubber last?
2. Daystar or some other brand?
WHEEL BEARINGS:
1. Where is the best place to get them?
2. Any specific brands you would recommend?
STEERING STABILIZER
OK, this one is not really shot, but it is rusted and has some encounters with rocks... Figured I may as well change it...
1. Any recommended brand, or just go with the cheap OEM replacements?
2. IF the Bilsteins are worth it, I have seen the DO make Steering Stabilizers, but I have yet to find one for the Jeep. I know the shocks have a coating to avoid rust, so that seems interesting (not to mention the whole set would match, making the Jeep look less like a color carnival). Is there one for the Jeep? Is it worth getting?
Thanks to all!
Felipe
SHOCKS:
BUSHINGS:
WHEEL BEARINGS:
STEERING STABILIZER
Thanks to all!
Felipe
