renix throttle body
blown XJ
Does anyone know if a renix throttle body can be bored out to accept a 60mm throttle plate? If I had a spare t body I'd just bore it and find out but i have no spare and no line on one. Thanks for any help
~blown~
I've seen those to.. Just was seeing if I could use the oarts I have layin around.. The turbo and its accessory have dried the jeep fund up
I ended up putting it in the mill at work and boring it out to use a factory ho throttle blade.. Took a while to get it set up but minutes to bore it out..
Idk yet haven't got a chance to start it. I also swapped to the 99+ intake manifold and added a t4 turbo running 10psi of boost. Milled .022" off the head and have 28lb/hr injectors.. Had to stop Workin on it to fix a blown head gasket/warped head on my fiancée 97 xj
