Mrsig
Member
Roof Drip Fix:
This will stop that PIA drip you get on your dash by the AC vent that drips down to the floor when you open the front doors of your JK when or after it rains!
1) Remove T tops
2) Drill a 1/8 hole on a angle by the lug to the rear of the T top in the rain channel. Drill it from the top side down.
This is the angle you will need to drill.
This is where the bit will come out.
3) Clean the area and hit with paint on both sides so the white color will not show.
I did this about 3 months ago and it works great!
I took the photos after I was done..
1) Remove T tops
