Baseline 4x4
Custom Design bolts directly to factory mounting locations for easy bolt on installation. Wiring harness plugs directly into existing wiring. Designed as a one-piece welded assembly for added strength, This Rugged Ridge built this Hitch Receiver to match the towing capacity of your Jeep: 3,500-lb tow rating, 350-lb tongue weight rating with weight distributing equipment; otherwise 2000-lb tow rating, 200-lb tongue weight rating, 2" opening.
11580.10 - Rugged Ridge Rear 2" Hitch, 07-11 Jeep JK Wrangler
17275.01 - Rugged Ridge TOW HITCH WIRING HARNESS, JEEP WRANGLER JK 07-11
Or buy these as a kit and save money
11580.51 - RUGGED RIDGE HITCH KIT, JEEP WRANGLER (JK) 07-11, INCLUDES HITCH AND WIRING HARNESS. HITCH RATED AT 3500LBS FOR 4DR AND 2000LBS FOR 2DR BLK
