Rugged Ridge Soft Top Sale at Baseline4x4.com 88-95 YJ's 97-TJ's, Tinted Windows
Baseline 4x4
5% off all Rugged Ridge Soft Tops and Free Shipping
New XHD Replacement Soft-Tops from Rugged Ridge are now available! These new designs feature reinforced stitching on the heavy “pull” areas as well as heavy duty 30 mil thick glass! This new glass is 50% thicker than previous Rugged Ridge Tops! Now the XHD Rugged Ridge Soft top has the same crystal clear DOT approved glass thickness as a Bestop replace-a-top but at a much more cost effective price point. All XHD Soft Tops feature durable vinyl coated polyester and cotton fabric that will last the test of time. All sewn seams use marine grade thread to make sure it does not deteriorate or discolor in the sun. Each seam is literally “welded shut” with durable heat seal tape to keep moisture out while keeping the original look of the top in tact. Just like the previous Rugged Ridge Tops, each top is backed by an industry leading 3 year limited warranty against manufacturer defects.
Features:
1.) DOT approved UV treated 30 mil plastic for long life and the ultimate in clarity.
2.) Durable 15 oz vinyl coated polyester and cotton fabric with “welded shut” seams that use durable heat seal tape to keep moisture out!
3.) Zip-out Side & Rear windows for Wranglers.
4.) XHD 30 mil glass is just as thick as Bestop’s Soft Tops.
5.) The most comprehensive line of replacement soft tops on the market, so you can choose what options are best for you.
6.) Backed by a 3 year limited warranty
1988 - 1995 Jeep YJ Wrangler
13721.09 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Charcoal, 30 Mil Glass, 88-95 Jeep YJ Wrangler
13721.15 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Black Denim, 30 Mil Glass, 88-95 Jeep YJ Wrangler
13721.37 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Spice, 30 Mil Glass, 88-95 Jeep YJ Wrangler
13722.09 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Charcoal, 30 Mil Glass, 88-95 Jeep YJ Wrangler
13722.15 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Black Den, 30 Mil Glass, 88-95 Jeep YJ Wrangler
13722.37 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Spice, 30 Mil Glass, 88-95 Jeep YJ Wrangler
1997 - 2002 Jeep TJ Wrangler
13723.15 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Black Denim, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13723.33 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Dark Tan, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13723.37 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Spice, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13724.15 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Black Denim, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13724.33 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Dark Tan, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13724.37 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Spice, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13725.15 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Denim Black, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13725.33 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Dark Tan, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13725.37 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Spice, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13726.15 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Tinted Windows, Black Denim, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13726.33 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Tinted Windows, Dark Tan, 30 Mil Glass, 97-02 Jeep TJ Wrangler
13726.37 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Tinted Windows, Spice, 30 Mil Glass, 97-02 Jeep TJ Wrangler
2003 - 2006 Jeep TJ Wrangler
13727.35 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Diamond Black, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13727.36 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Diamond Khaki, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13728.35 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Diamond Black, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13728.36 - Rugged Ridge XHD Replacement Soft Top With Upper Door Skins, Tinted Windows, Diamond Khaki, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13729.35 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Diamond Black, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13729.36 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Diamond Khaki, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13730.35 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Tinted Windows, Diamond Black, 30 Mil Glass, 03-06 Jeep TJ Wrangler
13730.36 - Rugged Ridge XHD Replacement Soft Top With Out Upper Door Skins, Tinted Windows, Diamond Khaki, 30 Mil Glass, 03-06 Jeep TJ Wrangler
