elevatorman
Ok I have an 87yj 4.2 that overheats daily.
since I began my resoration,I have replaced the thermostat,water pump,fan clutch,All hoses and vacuum lines,verified timing more than once,verified no cracked block or,water flow restrictions,I dont lose water,and I am not running lean.However it will get to 230-240 at times while driving down the frwy.It was getting hot and then would cool back down to 195 or so.Installed 2 other Thermostats one higher rated to hold the coolant in the radiator longer f and then one lower rated to open and let it flow sooner---No change
Can my winch and A/C condenser be blocking the air flow,Is this common and is the electric fan conversion the way to go?
I dont mind dropping the $ I just want it right.
I have a brand new radiator and coolant going in today and hope it solves the problem.
I have 3 cars,1 truck and my jeep my preferred cruiser so I need to fix her!
