running water?
peregrine1295
I have a very unusual problem with my 95 Grand Cherokee. when first starting in the morning everything seems normal, then when I start to drive I get the sound of tricking water or the sould of a small creek with running water in the passenger side dash. It may last for a minute or so then goes away. I have also noticed the coolant level is slowly going down. What is going on. when I park for two or three days no coolant on the ground. A friend suggusted the heater core is bad. Heater works fine. Any ideas or help would be greatly appriciated.:???:
Check the HVAC drain for restrictions. look under the passenger carpet and see if it's wet.
