++++++ATTENTION PILOTS AND SCIENTISTS++++++
I'm tired of our community being reduced to relying on "case-based" information and advice when it comes to soliciting help choosing accessories and parts for our vehicles. When I'm considering a certain component, or performance modifier, I want facts, not opinions! I think the Ramp Travel Index is one such instrument which allows scientific, fact based comparrison of different suspension components. You can take your rig to an RTI and get a number, then make a modification and see how the RTI changes. Whether the information is inherently applicable to the average off-roader is a topic for another forum, but the concept is interesting none-the-less.
Would it be of value to take a scientific approach to weight and balance issues also. In aviation, aircraft performance can be compared using the concept of weight and balance. Each airplane has a scientifically calculated center of gravity (the point on the fusalage at which the aircraft would balance on a fulcrum). Then, any weight (passengers, fuel, baggage, accessories, etc) can be plugged into a formula based on leverage's effect on the plane (another application of the torque concept). The [weight] of the object, times the distance from the center of gravity [arm] is equal to the [moment].
weight (lbs) x arm (inches) = moment (lb-inch)
If there were standardized stations such as 1) front bumper, 2)front seat, 3) rear seat or baggage compartment, 4) fuel tank, 5) rear bumper
then, various changes including bumper and winch combos, rear bumpers and tire/fuel/jack carrying configurations could all be compared in a standardized way. This is applicable when considering weight transfer and traction to front tires when going up hill, or vice versa when going downhill.
Just as weight's effect about the lateral axis (pitch, or front to back) could be comparred, so too could weight's effect about the longitudinal axis (roll, or side to side).
If someone took a stock jeep, and used blocks and jacks along the frame to find the point where the whole thing balanced front to rear, it would be easy to establish a standardized "arm" for front bumper, rear bumper, fuel tank, etc. Then, the only variable would be the weight of the object you're considering installing, and its effect on center of gravity could be measured. This specific calculation would, of course, only be applicable to going up or down a hill; however, if the same measurements (the arm) were established for various heights (frame height, cargo/passenger compartment, and roof rack), then the same formula could be used to compare different components and their effect on the jeep's tendency to roll.
These computations would certainly be affected by various heights of lift kit. Would this be a worthwhile pursuit, or in the experience of those older and wiser than I, does weight and balance not make that much of an issue in the long run.
Anxiously awaiting some responses,
Jon
Jon
