SeriousOffroad
Yes...Serious is right.
Thicker DOM.
Bored and taped for massive 7/8"-18tpi GM 1 Ton TRE's
Left and Right hand threads for easy adjustments and true fine tunning without the need to disassemble.
Wrench flats on all ends.
Dual poly spacers with every kit to eliminate the dreaded "Dead-Spot" common to lesser kits.
No Welding Required!!
Available with or without tapered inserts.
over the knuckle or under the knuckle kits available.
Available for TJ, XJ & ZJ's
Serious Steering <---click here
Or click on the pic
Thicker DOM.
Or click on the pic
